Normal Topic Remove binding of child nodes to ContainerNode (Read 3482 times)
Vitaliy
Feb 13th, 2017 at 1:44pm
I'd like to use ContainerNode only to show borders of process. For it need that child nodes doesn't move together with container. It's mean that I have to have possibility add child elements to area of ContainerNode, but child elements have to be not binded with container.
Maybe I have to use some other shape?
Re: Remove binding of child nodes to ContainerNode
Reply #1 - Feb 13th, 2017 at 1:50pm
Try setting container.AllowAddChildren = false and the container shouldn't become parent of dropped nodes. You might as well use TableNode without any rows if you only need the container node's appearance (rectangle with caption-bar).
Vitaliy
Reply #2 - Feb 14th, 2017 at 7:59am
Thank you for answer.
When I set container.AllowAddChildren = false I cannot drop nodes to ContainerNode area. But I will try TableNode
Reply #3 - Feb 14th, 2017 at 9:06am
Ok, adding children to container happens in its onDropOver method, so you could set it to an empty function in JavaScript if you won't be using the feature at all -
ContainerNode.prototype.onDropOver = function (item) {}
otherwise you could keep a reference to the original onDropOver function and apply it from your replacement depending on some flag you add to ContainerNodes.
