Hot Topic (More than 10 Replies) Add icon and additional text to node (Read 12255 times)
friedel
Mar 3rd, 2017 at 8:46am
Hello. I'd like to add to shape node an icon and additional text. How do I start? Maybe is there any sample?
friedel
Re: Add icon and additional text to node
Reply #1 - Mar 3rd, 2017 at 8:46am
The result I want
Reply #2 - Mar 3rd, 2017 at 9:31am
Do you need to use any shapes other than rounded rectangle? If not, you can get this out of the box using TableNode. Set the table's Shape property to SimpleShape.RoundedRectangle and CellFrameStyle to CellFrameStyle.None. The Review text from your image could be assigned to node's Text, and any additional icons and texts to respective properties of table cells.
edit: check the spanning cells sample from this page, it's an improved version of the one distributed with the library - http://mindfusion.eu/products/javascript/diagramming/samples
friedel
Reply #3 - Mar 3rd, 2017 at 9:53am
Thank your for your reply. But I have to use ShapeNodes, not TableNode. Can I add TableNode to ShapeNode?
Reply #4 - Mar 3rd, 2017 at 11:01am
Here's how you could custom-draw extra text -
var Alignment = MindFusion.Diagramming.Alignment;
var Text = MindFusion.Drawing.Text;
ShapeNode.prototype.onUpdateVisuals = function ()
	var content = this.graphicsContainer.content;
	var extraText = new Text(
		"User B",	// replace with this.yourFieldName
		this.getBounds().clone());
	extraText.textAlignment = Alignment.Center;
	extraText.lineAlignment = Alignment.Far;
	extraText.fitInBounds = true;
	extraText.font = this.getEffectiveFont();
	content.push(extraText);
If the icon includes some empty padding space, you could assign it to standard Image property and set ImageAlign to BottomLeft. Alternatively you can adjust image position from same onUpdateVisuals function as shown here -
http://mindfusion.eu/Forum/YaBB.pl?num=1439580359/1#1
If you need to add more images to same node -
var imageObj = new Image();
imageObj.src = "icon1.png";
// in onUpdateVisuals
var image2 = new MindFusion.Drawing.Image(
	new MindFusion.Drawing.Rect(this.bounds.x + 2, this.bounds.bottom() - 7, 5, 5));
image2.image = imageObj;
image2.loaded = imageObj.complete;
content.push(image2);
Instead of custom drawing, you could add extra images and texts by showing them in Transparent ShapeNodes attached to main node using attachTo method. That will let your users adjust their positions if desired, or you could set node.Locked to prevent that.
friedel
Reply #5 - Mar 3rd, 2017 at 12:17pm
Thanks, it's worked. But you see, I may have multiple lines on shapenode. I tried to add some Text() objects by content.push(text1), content.push(text2).
And it resulted in
I want something like that
Also I'd like, that users would be shown just after "Review" text.
Reply #6 - Mar 3rd, 2017 at 1:29pm
You can specify text bounding rectangles as second argument of Text constructor, e.g.
	for (var i = 0; i < 3; i++)
		// assume primary text is top-aligned
		var index = i + 1;
		var rect = this.getBounds().clone();
		rect.height = 2 * this.getEffectiveFontSize();
		rect.y += index * rect.height;
			rect);
friedel
Reply #7 - Mar 6th, 2017 at 9:06am
Hi, It's worked. But I have two another problems.
1. I want to hide inner text elements when resizing height and ShapeNode height become small. I can't find any property like visible/enabled
2. I want to forbid resizing ShapeNode width if it's getting smaller than text's width. But I can't find any property related to inner texts width.
Could you help me with that?
friedel
Reply #8 - Mar 6th, 2017 at 10:02am
Or is it possible to hide part of text?
Reply #9 - Mar 6th, 2017 at 10:18am
extraText.clipPath = this.shapeRenderer.getOutline();
friedel
Reply #10 - Mar 6th, 2017 at 10:56am
Thanks a lot. The only thing left is to hide node's primary text (in my case "Review")
Reply #11 - Mar 6th, 2017 at 11:48am
Its Text object is stored in DiagramItem.text field, so you could set this.text.clipPath = ...
friedel
Reply #12 - Mar 6th, 2017 at 1:12pm
Is it possible for additional text to have different font than main text?
I set extraText.font.style.bold = false and extraText.font.style.size = 7
But "Review" text also became non-bold and with changed size.
Reply #13 - Mar 6th, 2017 at 1:19pm
The Text objects are sharing same Font instance after this assignment -
Replace it with this -
extraText.font = new MindFusion.Drawing.Font(name, size, bold, italic, underline);
friedel
Reply #14 - Mar 31st, 2017 at 10:52am
Hi. Is it possible somehow get "icon1.png" original width and height?
Code (Javascript)
