Normal Topic Show in the calendar appointments from the previous day (Read 5007 times)
AncaZ
Mar 13th, 2017 at 9:12am
Is it possible to show in the calendar appointment 6 hour from the previous day? So the calendar would show visible appointments from the previous day and the current day.
Code (Java)
 getTimetableSettings().setStartTime(Integer.valueOf(0));
with this I can only set the start time at 0, but  not from the previous day.
Thank you.
Re: Show in the calendar appointments from the previous day
Reply #1 - Mar 13th, 2017 at 9:40am
You can set the date of the Timetable view to the day previous to the one you want to show. Then use the following settings:
calendar.getTimetableSettings().setStartTime(1080);
calendar.getTimetableSettings().setEndTime(2880);
This code indicates that the view will display the time from 18:00 of the current day, to 24:00 to the following day.
Let me know if this helps.
AncaZ
Reply #2 - Mar 13th, 2017 at 9:52am
I want to show the time like this:
From 12.03.2017 time 18.00 until 14.03.2017 time 06.00 .
Is it possible?
Thank you.
Reply #3 - Mar 13th, 2017 at 1:09pm
It is not possible to show more than two days in a single Timetable column. You need to add additional columns.
AncaZ
Reply #4 - Mar 13th, 2017 at 2:02pm
Thank you for your response.
But is it possible to show appointments from the previous day?
For example from 12.03.2017 time 22.00 until 13.03.2017 time 24.00.
So the goal would be to see also the appointments from yesterday.
Thank you.
Reply #5 - Mar 14th, 2017 at 8:27am
You can show the appointments from two days using the code I posted above. For this particular case, add 12.03.2017 to TimetableSettings.Dates and use the following settings:
calendar.getTimetableSettings().setStartTime(1320); // 22:00 PM
calendar.getTimetableSettings().setEndTime(2880); // 24:00 PM on the next day
AncaZ
Reply #6 - Mar 14th, 2017 at 10:06am
It works. Thank you Smiley
