MindFusion
  MindFusion Xamarin Pack beta version includes diagram, chart and calendar controls for Xamarin.Forms. Now beta testing Chart and Gauge components for Java Swing.
  HomeHelpSearchLoginRegister
Create a new appointment at single left click
Read 48 times
AncaZ   Offline
Mar 14th, 2017 at 11:10am
How can I create an appointment when I press left click on a cell? Not drag and drop.
I see the method that caches the left click event is:
Code (Java):
 @Override
            public void dateClick(ResourceDateEvent e) {
The problem is that here I don't have the item.
Do you have an example with the implementation of an Item object?
Thank you.
Meppy   Offline
Gender: male
Re: Create a new appointment at single left click
Reply #1 - Mar 14th, 2017 at 2:35pm
Your approach is correct. Simply create a new item in the dateClick method by using the specified date (and resource, if applicable) and add it to the schedule:
Code:
@Override
	calendar.resetDrag();
	Appointment app = new Appointment();
	app.setStartTime(e.getDate());
	app.setEndTime(e.getDate().addHours(2));
	if (e.getResource() != null)
		app.getResources().add(e.getResource());
	calendar.getSchedule().getItems().add(app);
Note the call to resetDrag. This is done to terminate the interaction that will start in response to the left click (e.g. select).
« Last Edit: Mar 14th, 2017 at 3:55pm by Meppy »
AncaZ   Offline
Reply #2 - Mar 14th, 2017 at 3:17pm
Works perfectly Smiley
Thank a lot.
