MindFusion
  MindFusion Xamarin Pack beta version includes diagram, chart and calendar controls for Xamarin.Forms. Now beta testing Chart and Gauge components for Java Swing.
  HomeHelpSearchLoginRegister
resizeToFitItems() after Lane node rotating 270degrees crops not corectly.
Read 48 times
tadeus   Offline
Mar 17th, 2017 at 12:24pm
Hello!
I heve created Lane node with RotationAngle = 270.
When I call resizeToFitItems() method it crops like Lane is not rotated:
How I can resolve this problem?
Thank You.
Slavcho   Offline
Gender: male
Re: resizeToFitItems() after Lane node rotating 270degrees crops not corectly.
Reply #1 - Mar 17th, 2017 at 1:20pm
It seems we disregard rotation when calculating new diagram bounds, try this as a fix for time being -
Code:
Diagram.prototype.getContentBounds = function ()
    var rect = Rect.empty;
    ArrayList.forEach(this.items, function (item)
        if (rect == Rect.empty)
            rect = item.getRotatedBounds();
        else
            rect = rect.union(item.getRotatedBounds());
    return rect;
edit: first getBounds becomes getRotatedBounds too
« Last Edit: Mar 17th, 2017 at 2:58pm by Slavcho »
tadeus   Offline
Reply #2 - Mar 20th, 2017 at 12:20pm
Thank You, it works.
Best Regards, Tadeus
