Normal Topic MindFusion WPF Available Features (Read 3583 times)
kelum
Mar 25th, 2017 at 5:51pm
Hi All,
We are interested about MindFusion WPF Diagram Library and planning to develop and customize diagram designer using mindfusion wpf library.
Before we proceed with your product(WPF Diagram Library), we want to confirm that following features available or not with your product.
Expecting Features
1. WPF Designer Canvas Layout should be able to zoom in zoom out. Zoom Out.
Zoom In with dashboard slider or text box and Mouse Scroll up and Down events
2. Create dynamic shapes in the programming level - Should be able to add new shapes in development level.
3. Shapes should be able to rotate - dropped shapes on to designer canvas should be able to rotate into any angle
4. Add Colors to shapes using dashboard color picker
5. Getting Mirror Image of a shape using mouse pointer drag or dashboard button.
6. Create Customized sized canvas layout
7. Adding text labels to shapes and adding idle labels to designer canvas.
8. Ruler for designer canvas - ruler needs to work with zoom in zoom out feature,
9. Shapes should be able to group and drag as individual or as a group
10. Limit or warning messages when shapes exceeds the designer canvas layout.
11. Limit or warning messages when shapes overlapping each other.
12. print the saved diagrams - Printout should be able to get in A4, A3 or split among 2 A4s ( landscape and portrait ).
13. Layout should be able to save as XML, pdf or as image file (PNG, JPEG, jpg).
14. Undo/Redo Features with keyboard key and dashboard button
15. Getting New canvas using dashboard button
please confirm those features available or not with your product.
regards
kelum
Online
Re: MindFusion WPF Available Features
Reply #1 - Mar 27th, 2017 at 6:17am
All except #5 are available. We've just implemented support for #5 in our Windows Forms control, and we'll sync it with WPF one soon -
http://mindfusion.eu/Forum/YaBB.pl?num=1490158804/3#3
kelum
Reply #2 - Mar 27th, 2017 at 10:22am
Thanks it helps
Online
Reply #3 - Mar 28th, 2017 at 11:11am
For #5 you can find ShapeNode.AllowFlip, FlipX and FlipY properties here -
https://mindfusion.eu/_beta/wpfdiag_flipshapes.zip
