Hot Topic (More than 10 Replies) Add new Command to 'Save as PDF' (Read 6139 times)
kelum
Apr 6th, 2017 at 5:21am
I'm trying to add new application command like 'Save as PDF'
So I created following `DesignerCanvas.Commands.cs` class and added following
        public partial class DesignerCanvas
        public static RoutedCommand SaveAsPDF = new RoutedCommand();
        public DesignerCanvas()
            this.CommandBindings.Add(new CommandBinding(DesignerCanvas.SaveAsPDF, SaveAsPDF_Executed));
        private void SaveAsPDF_Executed(object sender, ExecutedRoutedEventArgs e)
            throw new NotImplementedException();
then I created 'DesignerCanvas.cs'
    public partial class DesignerCanvas : Canvas
then Added new Icon to tool bar like this in 'ApplicationToolbar.xaml'
	<ResourceDictionary xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
                    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
                    xmlns:s="clr-namespace:SampleProject">
					<Button Margin="0,3,0,3" Padding="5" HorizontalContentAlignment="Left"
                            Style="{StaticResource ToolBarButtonBaseStyle}"
                            Command="{x:Static s:DesignerCanvas.SaveAsPDF}"
                            CommandTarget="{Binding ElementName=MyDesigner}">
                        <Button.Content>
                            <Grid>
                                <Grid.ColumnDefinitions>
                                    <ColumnDefinition/>
                                    <ColumnDefinition />
                                </Grid.ColumnDefinitions>
                                <Image Source="Images/Ungroup.png" Width="16"/>
                                <TextBlock Margin="3" Text="Ungroup" VerticalAlignment="Center" Grid.Column="1"/>
                            </Grid>
                        </Button.Content>
     </ResourceDictionary>
but here I'm getting this error
The name "DesignerCanvas" does not exist in the namespace "clr-namespace:SampleProject".
Re: Add new Command to 'Save as PDF'
Reply #1 - Apr 6th, 2017 at 7:46am
You might have to recompile the project for the Xaml designer to find that class.
kelum
Reply #2 - Apr 6th, 2017 at 9:30am
I implemented following method to Save canvas to PDF ?
            SaveFileDialog saveDlg = new SaveFileDialog();
            saveDlg.Filter = "PDF files|*.pdf";
            if (saveDlg.ShowDialog() == true)
                flowchart.SaveToXml(saveDlg.FileName);
                MindFusion.Diagramming.Export.PdfExporter pdfExp = new MindFusion.Diagramming.Export.PdfExporter();
                pdfExp.Export(diagramview.Diagram, saveDlg.FileName);
above method I refreed from mindfusion documentation page
http://www.mindfusion.eu/onlinehelp/flowchartnet/Diagram_Exporting.htm
but here I'm having following errors
Error 1
'Diagram' does not contain a definition for 'Diagram' and no extension method 'Diagram' accepting a first argument of type 'Diagram' could be found
Error 2
The type or namespace name 'Export' does not exist in the namespace 'MindFusion.Diagramming'
but for this(2nd error) I already installed `MindFusion.Diagramming.Wpf` and gave namespace like this
`using MindFusion.Diagramming.Wpf;`
Reply #3 - Apr 6th, 2017 at 1:05pm
That link is to help files of our Windows Forms component. WPF version is here -
http://www.mindfusion.eu/onlinehelp/wpfdiagram/index.htm?CC_Exporting_the_Diagra...
kelum
Reply #4 - Apr 7th, 2017 at 3:45am
once I add I'm having following compile time errors
The type or namespace name 'PdfExporter' could not be found
The type or namespace name 'Pdf' does not exist in the namespace 'MindFusion'
Reply #5 - Apr 7th, 2017 at 8:50am
Right-click the project and choose Add Reference command, then browse to the installed dll files and select mindfusion.pdf.dll
kelum
Reply #6 - Apr 7th, 2017 at 10:17am
I found mindfusion.pdf.dll from below link
http://api.256file.com/mindfusion.pdf.dll/en-download-124273.html
once after add that
'The type or namespace name 'Pdf' does not exist in the namespace 'MindFusion' this error goes away
but I unable to solve below error
'The type or namespace name 'PdfExporter' could not be found'
Reply #7 - Apr 7th, 2017 at 10:43am
Eh, better don't download these from random websites. You should also add a reference to the MindFusion.Diagramming.Wpf.PdfExport.dll assembly. You'll have it installed under C:\Program Files\MindFusion if you've ran the control's installer. You might as well get all the assemblies as a nuget package -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/
kelum
Reply #8 - Apr 7th, 2017 at 11:14am
can you give the exact 'MindFusion.Diagramming.Wpf.PdfExport.dll' as attachment here , because I cant find though I installed Nuget package like this 'Install-Package MindFusion.Diagramming.Wpf'
Reply #9 - Apr 7th, 2017 at 11:32am
It should be available under project_path\packages\MindFusion.Diagramming.Wpf.3.4.2\lib\net40 after you install nuget package. Only the core assemblies are added automatically as references, you'll need to browse to that folder to select exporter's ones.
kelum
Reply #10 - Apr 11th, 2017 at 3:35am
I copied the `MindFusion.Diagramming.Wpf.PdfExport.dll` from my following location
`Project_Location\packages\MindFusion.Diagramming.Wpf.3.4.2\lib\net40`
then I gave referred following namespace
`using MindFusion.Diagramming.Wpf.Export;`
but then Still I'm having following compile time errors
1. `The name 'PageSize' does not exist in the current context`
2. `The type 'PageOrientation' is defined in an assembly that is not referenced. You must add a reference to assembly 'MindFusion.Pdf, Version=1.3.0.13478, Culture=neutral, PublicKeyToken=0b3a610038a66854'`
3. `The type 'PageSize' is defined in an assembly that is not referenced. You must add a reference to assembly 'MindFusion.Pdf, Version=1.3.0.13478, Culture=neutral, PublicKeyToken=0b3a610038a66854'`
4. `The type or namespace name 'Pdf' does not exist in the namespace 'MindFusion`
Reply #11 - Apr 11th, 2017 at 8:28am
Also add a reference to MindFusion.Pdf.dll and a 'using MindFusion.Pdf' clause to import its namespace.
