MindFusion
  Version 2 of our Xamarin Calendar component adds Resource view and support for Universal Windows Platform. Now beta testing spreadsheet component for Java Swing.
  HomeHelpSearchLoginRegister
Diagram with custom Node - Image not shown first load
Read 146 times
Ghaith   Offline
Apr 7th, 2017 at 1:41pm
I have created a custom node containing couple of text and images, and was working fine, but the nodes started to load with the text only, and the images is not there, until I click on the node, then the images appeared. I don't know If it is because something I did or some property I changed.
I checked the console in Chrome, the function "updateCanvasElements" already called and the images are pushed.
I tested on IE, everything is okay as usual.
I searched, but nothing I could found or someone having the same problem.
Any Ideas? Hin?
« Last Edit: Apr 7th, 2017 at 3:04pm by Ghaith »
Slavcho   Offline
Gender: male
Re: Diagram with custom Node - Image not shown first load
Reply #1 - Apr 7th, 2017 at 4:47pm
The DOM image might have not downloaded yet the first time you try to draw it. You could check the image.complete property, and if it's false call diagram.repaint() to schedule a redraw. You could as well subscribe to the image.load event. That's similar to what was discussed in this thread - http://mindfusion.eu/Forum/YaBB.pl?num=1488530760/15#15
Ghaith   Offline
Reply #2 - Apr 7th, 2017 at 7:32pm
Dear this is the code I am using
//Add image
var imgFile = new Image();
imgFile.src = 'data:image/png;base64,' + f.value;
imgFile.addEventListener("load", function () {
var img = new MindFusion.Drawing.Image(
new MindFusion.Drawing.Rect(this.bounds.x + p.position_X, this.bounds.y + p.position_Y, p.width, p.height));
img.image = imgFile;
img.loaded = imgFile.complete;
this.graphicsContainer.content.push(img);
but this didn't help
Slavcho   Offline
Gender: male
Reply #3 - Apr 8th, 2017 at 12:43pm
Try this handler -
Code:
	img.loaded = true;
	node.invalidate();
Ghaith   Offline
Reply #4 - Apr 10th, 2017 at 2:44pm
That solved the problem.
Many thanks
