MindFusion
  Version 2 of our Xamarin Calendar component adds Resource view and support for Universal Windows Platform. Now beta testing spreadsheet component for Java Swing.
  HomeHelpSearchLoginRegister
Pages: 1 2  Send Topic Print
move selected node using arrow keys
Read 731 times
Slavcho   Offline
Gender: male
Re: move selected node using arrow keys
Reply #15 - Apr 20th, 2017 at 11:11am
Modify the FindOverlaps method to take bounds argument -
Code:
List<DiagramNode> FindOverlaps(
	DiagramNode modifiedNode, Rect bounds, double minDist)
	bounds.Inflate(minDist - 1, minDist - 1);
	var overlaps = new List<DiagramNode>();
Older places where you call it such as OnNodeModifying, also pass node.Bounds like FindOverlaps(e.Node, e.Node.Bounds, 5). In arrow-key movements methods add an if statement that checks whether new rect leads to overlaps before assigning it -
Code:
var rect = node.Bounds;
rect.X = rect.Left - 10;
if (FindOverlaps(node, rect, 5).Count == 0)
    node.Move(node.Bounds.Left - 10, node.Bounds.Top);
kelum   Offline
Reply #16 - Apr 20th, 2017 at 6:47pm
so as you mentioned I changed code
Code:
        List<DiagramNode> FindOverlaps(DiagramNode modifiedNode, Rect bounds, double minDist)
            foreach (var node in flowchart.Nodes)
                if (modifiedNode == node)
                    continue;
                if (bounds.IntersectsWith(node.Bounds))
                    overlaps.Add(node);
            return overlaps;
and all the arrow key operations changed as follows
Code:
            // left arrow handler
            flowchart.CommandBindings.Add(
                new CommandBinding(Diagram.NavigateLeft, (sender, args) =>
                    foreach (var node in flowchart.Selection.Nodes)
                        if (node != null && node.Bounds.Left - 10 >= flowchart.Bounds.Left && (FindOverlaps(node, rect, 5).Count == 0))
            // right arrow handler
                new CommandBinding(Diagram.NavigateRight, (sender, args) =>
                        if (node != null && node.Bounds.Right + 10 <= flowchart.Bounds.Right && (FindOverlaps(node, rect, 5).Count == 0))
                            node.Move(node.Bounds.Left + 10, node.Bounds.Top);
            // up arrow handler
                new CommandBinding(Diagram.NavigateUp, (sender, args) =>
                        if (node != null && node.Bounds.Top - 10 >= flowchart.Bounds.Top && (FindOverlaps(node, rect, 5).Count == 0))
                            node.Move(node.Bounds.Left, node.Bounds.Top - 10);
            // down arrow handler
                new CommandBinding(Diagram.NavigateDown, (sender, args) =>
                        if (node != null && node.Bounds.Bottom + 10 <= flowchart.Bounds.Bottom && (FindOverlaps(node, rect, 5).Count == 0))
                            node.Move(node.Bounds.Left, node.Bounds.Top + 10);
this is compiling without errors, but in here once move one node over other node (overlap) then its locking each other, by selecting one of that overlapped node I can't move node away using arrow keys
Slavcho   Offline
Gender: male
Reply #17 - Apr 21st, 2017 at 6:40am
rect.X = rect.Left - 10 is only valid when you move to the left, you'll need to alter this expression for other directions.
If you allow nodes to overlap at any point, than offsetting by just 10 pixels might not find a non-overlapping position so it won't accept the movement. You might want to change the logic so that it always accepts movement if the moved node currently overlaps with another one.
kelum   Offline
Reply #18 - Apr 21st, 2017 at 10:04am
so as you mentioned I'updated code,
then Left Arrow Key and Up Arrow Key started to working properly (which is i can close up to 5 pixels, then those are not overlap)
Code:
            diagram.CommandBindings.Add(
                    foreach (var node in diagram.Selection.Nodes)
                        if (node != null && node.Bounds.Left - 10 >= diagram.Bounds.Left && (FindOverlaps(node, rect, 2).Count == 0))
		   // up arrow handler
                        rect.Y = rect.Top - 10;
                        if (node != null && node.Bounds.Top - 10 >= diagram.Bounds.Top && (FindOverlaps(node, rect, 2).Count == 0))
Left Arrow Key Operation with proper distance
Up Arrow Key Operation with proper distance
but Right arrow key and Bottom Arrow key not working like Left Arrow Key and Up Arrow Key , which is can't close up to 5 pixels they are locating with different spaces
Code:
                        rect.X = rect.Right + 10;
                        if (node != null && node.Bounds.Right + 10 <= diagram.Bounds.Right && (FindOverlaps(node, rect, 2).Count == 0))
                        rect.Y = rect.Bottom + 10;
                        if (node != null && node.Bounds.Bottom + 10 <= diagram.Bounds.Bottom && (FindOverlaps(node, rect, 2).Count == 0))
Bottom Arrow Key Operation with wide distance
Right Arrow Key Operation with wide distance
How can I reduce more spaces in right and down arrow handlers like up and left handlers
kelum   Offline
Reply #19 - Apr 21st, 2017 at 10:17am
Anyway I found the solution like this,
Code:
            // up arrow handler
                        rect.X = rect.Left + 10;
                        rect.Y = rect.Top + 10;
let me know if you have suggestion
Slavcho   Offline
Gender: male
Reply #20 - Apr 21st, 2017 at 11:05am
It should look like this as you've found, otherwise it didn't match the positions where you are moving the node on next line -
// right
// down
