Normal Topic Met a problem in putting two diagrams on a web page (Read 1896 times)
Toyogray
May 3rd, 2017 at 7:17am
I am putting TWO diagrams on a web page (just like the attached image, its main structure is ported from flowcharter example), but while drag&drop a new shape from NodeListView #2, put it on Diagram #2, but the result shape is always shown on Diagram #1.
Is there any way to make it working correctly (NodeListView #1 shape -> Diagram #1; NodeListView #2 shape -> Diagram #2)?
Or more precisely, how to disable Diagram #1 (or make Diagram #2 active) while dragging NodeListView #2 shapes?
Thanks.
Re: Met a problem in putting two diagrams on a web page
Reply #1 - May 3rd, 2017 at 8:57am
We could not reproduce this, please let me know what we should change in attached project to see it happen. What versions of the control and browser are you using?
Toyogray
Reply #2 - May 5th, 2017 at 8:01am
Hi Slavcho,
Thanks for your fast & kind reply. According to the provided project, I have confidence in the diagram component. After part-by-part porting, I found it was cause by my bad HTML design and wrong JQuery usage. This problem has been solved now.
Thanks for your help.
