Normal Topic Scheduling DragDrop Sample (Read 3444 times)
fractal07
May 10th, 2017 at 7:52pm
I'm working (VS2015, C#, Winforms) on a timetable inspired from the Scheduling DragDrop Sample and I'm still stuck on a drawing issue : I do not succeed to manage the size (the height) of the rectangle drawn when I'm creating an appointment by dragging an image ( as the sample shows), the box still displays a 1h00 height while I use a 0h30 cellTime!
However, once the appointment is created, if I move it the cell height is correct (=0h30)..
It's pretty difficult to debug dragging events so if someone understood my issue and have an idea... Thank you!
Re: Scheduling DragDrop Sample
Reply #1 - May 11th, 2017 at 7:36am
If you want to custom-draw only a single cell (rather than 2 consecutive cells as demonstrated by the sample), check the modified version of the sample below:
https://mindfusion.eu/_samples/_sample_DragDrop.zip
If you need something else, please, attach an image illustrating the end result.
fractal07
Reply #2 - May 11th, 2017 at 1:51pm
Thank you Meppy, it's perfectly clear now!
I checked in the original file, comments were good but, at first, I didn't understood them...  Thank you again!
