Normal Topic Do you have a custom link example? (Read 2426 times)
chowy
Jun 29th, 2017 at 2:46am
Do you have a custom link example? I want to create my own link class, inherited from diagramlink. And, I want to set the link only to connect to the anchor point. I found the installation package demo, almost no examples of custom link. I want to learn more about this link. Grin
Online
Re: Do you have a custom link example?
Reply #1 - Jun 29th, 2017 at 6:23am
Try this -
class MyLink : DiagramLink
	public MyLink(Diagram parent) : base(parent)
		MyProperty = "go there";
	public override void Draw(
		System.Windows.Media.DrawingContext graphics,
		MindFusion.Diagramming.Wpf.RenderOptions options)
		base.Draw(graphics, options);
		var width = Parent.MeasureString(MyProperty, this, 1000).Width + 10;
		var bounds = new Rect(
			EndPoint, new Size(width, 100));
		if (EndPoint.X > StartPoint.X)
			bounds.Offset(-bounds.Width, 0);
		bounds.Offset(-Bounds.X, -Bounds.Y);
		Parent.DrawStyledText(graphics, MyProperty, this, bounds);
	protected override void SaveToXml(XmlElement xmlElement, XmlPersistContext context)
		base.SaveToXml(xmlElement, context);
		context.WriteString(MyProperty, "MyProperty", xmlElement);
	protected override void LoadFromXml(XmlElement xmlElement, XmlPersistContext context)
		base.LoadFromXml(xmlElement, context);
		MyProperty = context.ReadString("MyProperty", xmlElement);
	public string MyProperty { get; set; }
public partial class MainWindow : Window
	public MainWindow()
		InitializeComponent();
		Diagram.RegisterItemClass(typeof(MyLink), "my:MyLink", 100);
		diagram.Behavior = Behavior.Custom;
		diagram.CustomLinkType = typeof(MyLink);
		diagram.AllowUnanchoredLinks = false;
		diagram.SnapToAnchor = SnapToAnchor.OnCreateOrModify;
chowy
Reply #2 - Jun 29th, 2017 at 8:26am
Slavcho wrote on Jun 29th, 2017 at 6:23am:
Try this -
	public MainWindow()
By the way, I would like to ask about printing. Can WPF versions support printing by region? Like winform fit fit to page and switch horizontal or portrait.Thanks!!
Online
Reply #3 - Jun 29th, 2017 at 9:04am
It's only available in WinForms version out of the box at this time. For WPF one you can implement landscape and custom page sizes as shown here -
http://mindfusion.eu/Forum/YaBB.pl?num=1261177195/4#4
Setting PrintOptions.Scale to something like 100 * page size / diagram size should let you fit inside a page.
