General >> News >> MindFusion.WebForms Pack, 2015.R1 beta
https://mindfusion.eu/Forum/YaBB.pl?num=1435154349 Message started by Stoyo on Jun 24th, 2015 at 1:59pm |
Title: MindFusion.WebForms Pack, 2015.R1 beta Post by Stoyo on Jun 24th, 2015 at 1:59pm
WebForms Pack 2015.R1 contains the following new features and improvements:
Licensing There is no separate trial build of the control assemblies anymore. Instead, set the LicenseKey property of the individual components to disable the component's evaluation mode and stop displaying trial messages. If your application contains more than one control by MindFusion, you could call MindFusion.Licensing.LicenseManager.AddLicense(key) to specify the key once instead of setting it per each control. License key strings are listed on the Keys & Downloads page at MindFusion's customer portal. Visual Studio 2015 Toolbox Support MindFusion.WebForms components can now be installed automatically into Visual Studio 2015 toolbox palette. MindFusion.Charting The list below describes recent changes and additions to MindFusion.Charting for WebForms: Custom Formatting of Labels for Line charts Line charts now support custom formatting of labels. It is used when the number format property is set to NumberFormat.Custom. The properties that set the custom number format use the custom format strings for .net. To use custom formatting, set LabelFormat to NumberFormat.Custom and use LabelCustomFormat. Sorted Bars The algorithm for sorting of bars has been improved. Bars in a series or in clusters can be sorted in ascending or descending order - use the SortOrder property. You can also sort each series/cluster with the SortSeriesBy property. Bar can be sorted with their colors preserved if SortColor is set to true. Miscellaneous
MindFusion.Diagramming The list below describes recent changes and additions to MindFusion.Diagramming for WebForms: Canvas mode improvements
Styled text in Canvas mode The EnableStyledText property of ShapeNode allows using HTML-like formatting tags to apply various attributes to the node's text. At this time the component supports the following formatting tags: <b> specifies bold text <i> specifies italic text <u> specifies underlined text <color=value> specifies text color <br /> specifies line break Zoom control (not available in JavaApplet mode) The ZoomControl class lets users change interactively the current zoom level and scroll position of a DiagramView. To set it up, add a ZoomControl element to the page and set the control's TargetId property to the id of a DiagramView. Set the ZoomStep and ScrollStep properties to specify the amount added to diagram's zoom level or scroll position by ZoomControl's buttons. You can customize the control's appearance by setting properties such as Fill, BorderColor, CornerRadius and TickPosition. Miscellaneous
MindFusion.Gauges Linear and oval gauge controls have been added to MindFusion.WebForms pack. The gauges are drawn on client side using HTML Canvas API. Users can change gauge values interactively by dragging their elements. MindFusion.Scheduling The list below describes recent changes and additions to MindFusion.Scheduling for WebForms: Horizontal Timetable view Horizontal layout has been added to the Timetable view. The horizontal timetable view displays a collection of rows where each row represents the allotment of resources to distinct hours of a day; the rows in this view represent dates, tasks, locations, contacts or resources. The rows can be grouped by location, task, contact or resource. Each column represents an hour or a custom time interval. You can switch between horizontal and vertical layouts of the Timetable view by setting its Orientation property. Miscellaneous
MindFusion.UI The list below describes recent changes and additions to MindFusion.UI for WebForms: Miscellaneous
If anyone is interested in trying the beta version, please download this archive containing the full WebForms pack installer: https://mindfusion.eu/_beta/WebFormsPack.zip Any comments, questions and general feedback are welcome. |
