Virtual Keyboard Components >> Windows Forms >> Set single key color
https://mindfusion.eu/Forum/YaBB.pl?num=1463772878
Message started by Jim on May 20th, 2016 at 7:34pm
Title: Set single key color
Post by Jim on May 20th, 2016 at 7:34pm
Is possible to change background (also hover & pressed background too) color of a single key on the keyboard at runtime?
Also, how to lock to capslock on a shift doubleclick/doublepress?
Title: Re: Set single key color
Post by Slavcho on May 21st, 2016 at 5:51am
At this time painting keys in distinct colors can be done only through a custom KeyTemplate, for example this paints a red Enter key -
class MyTemplate : KeyTemplate
     public MyTemplate()
           defaultBrush = Background;
     GradientBrush defaultBrush;
     public override void Draw(Graphics g, Key key, Mode mode, Font font)
           if (key.Equals(Key.ENTER))
                 Background = new GradientBrush(
                       new List<Color> { Color.Red },
                       new List<float> { 0f }, 0f);
                 base.Draw(g, key, mode, font);
                 Background = defaultBrush;
                 return;
kb.KeyTemplate = new MyTemplate();[/code]
Post by Slavcho on May 21st, 2016 at 6:05am
One way I can see to enable CapsLocks is calling Key.CAPSLOCK.Send method. There's no Key-DoubleClicked event available, instead you might hadle KeyPressed and check the time to determine if it's a double click -
void OnKeyPressed(object sender, VirtualKeyEventArgs e)
     if (e.Key.Equals(Key.SHIFT))
           if (lastClick != null &&
                 DateTime.Now - lastClick.Value < TimeSpan.FromSeconds(0.5))
                 Key.CAPSLOCK.Send(true);
           lastClick = DateTime.Now;
}[/code]
