Grid and Spreadsheet Components >> Windows Forms >> Check the number of rows in a worksheet
https://mindfusion.eu/Forum/YaBB.pl?num=1470723883
Message started by antoan.73 on Aug 9th, 2016 at 6:24am
Title: Check the number of rows in a worksheet
Post by antoan.73 on Aug 9th, 2016 at 6:24am
Hi, is there a simple way to get the number of rows (and columns) in a worksheet that actually contain data? I tried Worksheet.Rows.Count, but it return the total number of rows.
Cheers
Title: Re: Check the number of rows in a worksheet
Post by Meppy on Aug 9th, 2016 at 7:43am
You can enumerate the Worksheet.Cells collection - it should iterate only over the cells containing data. The following code snippet illustrates how to do this:
Code (]// Load the workbook from a file
Workbook workbook = new Workbook();
ExcelImporter importer = new ExcelImporter();
importer.Import(@"c:\Users\Meppy\Hearthstone.xlsx", workbook);
// Obtain the first worksheet
var worksheet = workbook.Worksheets[0):
// Iterate over the worksheet cells and collect the max row and column
int column = worksheet.Cells.Max(cell => cell.Column) + 1;
int row = worksheet.Cells.Max(cell => cell.Row) + 1;
// Display the result
Debug.WriteLine("columns: {0}, rows: {1}", column, row);
Let me know if this helps.
Meppy
