Flow Diagramming Components >> ASP.NET >> resizeToFitItems() after Lane node rotating 270degrees crops not corectly.
https://mindfusion.eu/Forum/YaBB.pl?num=1489749843 Message started by tadeus on Mar 17th, 2017 at 11:24am |
Title: resizeToFitItems() after Lane node rotating 270degrees crops not corectly. Post by tadeus on Mar 17th, 2017 at 11:24am
Hello!
I heve created Lane node with RotationAngle = 270. When I call resizeToFitItems() method it crops like Lane is not rotated: How I can resolve this problem? Thank You. |
Title: Re: resizeToFitItems() after Lane node rotating 270degrees crops not corectly. Post by Slavcho on Mar 17th, 2017 at 12:20pm
It seems we disregard rotation when calculating new diagram bounds, try this as a fix for time being - [code] Diagram.prototype.getContentBounds = function () { var rect = Rect.empty; ArrayList.forEach(this.items, function (item) { if (rect == Rect.empty) rect = item.getRotatedBounds(); else rect = rect.union(item.getRotatedBounds()); }); return rect; }[/code] edit: first getBounds becomes getRotatedBounds too Regards, Slavcho |
Title: Re: resizeToFitItems() after Lane node rotating 270degrees crops not corectly. Post by tadeus on Mar 20th, 2017 at 11:20am
Thank You, it works.
Best Regards, Tadeus |
