Flow Diagramming Components >> Windows Forms >> How to add multiple text to a node?
https://mindfusion.eu/Forum/YaBB.pl?num=1493952507 Message started by Gu Wenwei on May 5th, 2017 at 2:48am |
Title: How to add multiple text to a node? Post by Gu Wenwei on May 5th, 2017 at 2:48am
Title: Re: How to add multiple text to a node? Post by Slavcho on May 5th, 2017 at 8:29am
Use either TableNode with multiple cells or CompositeNode with multiple TextComponents. If you prefer ShapeNodes, you could set CustomDraw = Additional and draw more text by calling e.Graphics.DrawString from DrawNode event handler.
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Oct 12th, 2017 at 5:30am
Excuse me, can you give me an example?
Title: Re: How to add multiple text to a node? Post by Slavcho on Oct 12th, 2017 at 5:47am
For TableNodes check ClassDiagram or InteractiveTable examples. For CompositeNodes check the Scripting and Demo (EmployeeNode.cs) examples. For custom drawing example see e.g. https://mindfusion.eu/Forum/YaBB.pl?num=1355256377/3#3 , you will need to set node's CustomDraw property to get the event raised.
Regards, Slavcho |
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Oct 15th, 2017 at 9:20am
Can Override Shape to Add multiple text?
Title: Re: How to add multiple text to a node? Post by Slavcho on Oct 16th, 2017 at 5:33am
You can create a custom node class and override its DrawLocal method -
[code] class ShapeNodeEx : ShapeNode { public string MoreText { get; set; } public override void DrawLocal(IGraphics graphics, RenderOptions options) { base.DrawLocal(graphics, options); graphics.DrawString(MoreText, EffectiveFont, Brushes.Black, 1, 1); } }[/code] Alternatively keep an array of strings as value of Tag property, and draw them in a loop from DrawNode event handler with CusotmDraw property set. Regards, Slavcho |
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Dec 20th, 2017 at 2:09pm
how to Create a ShapeNodeEx?
Cannot that: ShapeNodeEx b = diagram.Factory.CreateShapeNode(pt, new SizeF(20, 20)); |
Title: Re: How to add multiple text to a node? Post by Slavcho on Dec 20th, 2017 at 4:01pm
var b = new ShapeNodeEx(); b.Bounds = new RectangleF(...); diagram.Nodes.Add(b);[/code] Regards, Slavcho |
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Mar 10th, 2018 at 1:04pm
How do I put the position of SHAPE in the center?
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Mar 11th, 2018 at 3:25am
b.TextFormat.Alignment = StringAlignment.Center;
b.TextFormat.LineAlignment = StringAlignment.Center; |
Title: Re: How to add multiple text to a node? Post by Slavcho on Mar 12th, 2018 at 8:44am
Use the DrawString overload that takes a Rectangle and StringFormat arguments, passing node.GetLocalBounds() and your StringFormat as values.
Regards, Slavcho |
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Mar 13th, 2018 at 2:51am
thx
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Apr 22nd, 2018 at 1:30pm
how to convert diagram.Nodes to ShapeNodeEx?
Title: Re: How to add multiple text to a node? Post by Slavcho on Apr 23rd, 2018 at 5:37am
Nodes could contain instances of multiple types. You can use the as operator to determine type while looping over the collection -
Code (] foreach (var node in diagram.Nodes) { var exNode = node as ShapeNodeEx; if (exNode != null) ... } [/code):
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Apr 23rd, 2018 at 12:28pm
private void LoadFCSfile(string fn)
{ diagramView.LoadFromFile(fn); bool btag = false, bp = false; foreach (DiagramNode node in diagram.Nodes) { if (node is ControlNode) { btag = true; } else { ShapeNodeEx b = node as ShapeNodeEx; if (b.Shape.ToString() == "MyBlock") //b is null, ShapeNode b, OK { bp = true; } } } } b is null when ShapeNodeEx is ShapeNode, OK |
Title: Re: How to add multiple text to a node? Post by Slavcho on Apr 23rd, 2018 at 4:38pm
Try with -
[code] if (b != null && b.Shape.ToString() == "MyBlock") [/code] |
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Apr 24th, 2018 at 3:22am
ShapeNode B = node as ShapeNode;
B not null ShapeNodeEx B = node as ShapeNodeEx; B is null I want to get the data from B |
Title: Re: How to add multiple text to a node? Post by Slavcho on Apr 24th, 2018 at 6:08am
You aren't adding ShapeNodeEx-es to diagram.Nodes then, if building diagrams from code. If you are letting users draw interactively, set DiagramView.Behavior = Custom and CustomNodeType = typeof(ShapeNodeEx) to get ShapeNodeEx instances.
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Apr 25th, 2018 at 1:46am
how to save and open?
Title: Re: How to add multiple text to a node? Post by Slavcho on Apr 25th, 2018 at 7:25am
Call RegisterItemClass() to register your custom type for serialization. Implement either SaveTo / LoadFrom methods for binary serialization or SaveToXml / LoadFromXml ones for XML one. E.g. see these topics -
https://mindfusion.eu/Forum/YaBB.pl?num=1203351980/0#0 https://mindfusion.eu/Forum/YaBB.pl?num=1336836718/3#3 |
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Apr 25th, 2018 at 1:10pm Code (c++):
But the data is disorganized after loading |
Title: Re: How to add multiple text to a node? Post by Slavcho on Apr 25th, 2018 at 3:55pm
You must save and load your property values from respective methods implementations -
[code] protected override void SaveTo(System.IO.BinaryWriter writer, PersistContext ctx) { base.SaveTo(writer, ctx); writer.Write(MoreText); } protected override void LoadFrom(System.IO.BinaryReader reader, PersistContext ctx) { base.LoadFrom(reader, ctx); MoreText = reader.ReadString(); }[/code] |
Title: Re: How to add multiple text to a node? Post by Gu Wenwei on Apr 29th, 2018 at 7:40am
Perfect,
Thx |
