Flow Diagramming Components >> ASP.NET >> VISIO export- Add header in diagrams
https://mindfusion.eu/Forum/YaBB.pl?num=1510239224 Message started by Ron Floyd on Nov 9th, 2017 at 2:53pm |
Title: VISIO export- Add header in diagrams Post by Ron Floyd on Nov 9th, 2017 at 2:53pm
HI,
Is there any way where we can add the header in the diagram that we export it in VISIO. I already have javascript license and I am trying out the ASP.NET dll to download mindfusion diagrams in the VISIO. Please reply. Thanks, Ron |
Title: Re: VISIO export- Add header in diagrams Post by Slavcho on Nov 9th, 2017 at 3:02pm
If by headers you mean ones added via Diagram.LaneGrid, you can export the grid as Visio's Functional Band object by setting the VisioExporter.ExportLanes property. Regards, Slavcho Mindfusion |
Title: Re: VISIO export- Add header in diagrams Post by Ron Floyd on Nov 10th, 2017 at 1:10pm
HI Slavcho,
Thank you for your response. Is there any way where I can find the example? I am using JSON data to create Diagram Nodes and Links using DiagramView class. Is there any way where I can create a header text in the exported VISIO diagram, which will basically be the info about what the diagram is about. Thanks, Ron |
Title: Re: VISIO export- Add header in diagrams Post by Slavcho on Nov 10th, 2017 at 1:41pm
Hi Ron,
If only that, you could implement the header as a locked ShapeNode on top of the diagram, possibly using a different styling than the actual nodes. Add it temporarily before export if it shouldn't be shown on screen but only when exported. Regards, Slavcho |
