Flow Diagramming Components >> News >> Diagramming for Xamarin, V1.2
https://mindfusion.eu/Forum/YaBB.pl?num=1511362979 Message started by Forum Admin on Nov 22nd, 2017 at 3:02pm |
Title: Diagramming for Xamarin, V1.2 Post by Forum Admin on Nov 22nd, 2017 at 3:02pm
We have released version 1.2 of Xamarin Diagram control. It contains the following new features and improvements:
Universal Windows Platform The Diagram control can now be used in UWP Xamarin.Forms applications. Support for UWP is implemented by the MindFusion.Diagramming.Universal.dll assembly. Flip shapes The shape of a ShapeNode can be flipped horizontally or vertically. Enable the AllowFlip property and the shape flips when an edge is dragged over its opposite edge. You can get or set current flip state using FlipX and FlipY properties. Miscellaneous Behavior.PanAndModify lets you select and modify when touch gesture starts over an item, or pan the view otherwise. The latest version can be downloaded here, or from the clients area on our site: https://mindfusion.eu/XamarinDiagram.zip Updated assemblies are also available as MindFusion.Diagramming.Xamarin NuGet package. Enjoy! |
