Flow Diagramming Components >> WPF >> Diagram.IsLicensed takes a long time to execute
https://mindfusion.eu/Forum/YaBB.pl?num=1530804584 Message started by milosa on Jul 5th, 2018 at 3:29pm |
Title: Diagram.IsLicensed takes a long time to execute Post by milosa on Jul 5th, 2018 at 3:29pm
Hello,
I have the large diagram, 210 ContainerNodes, each having ~10 ShapeNodes and ~10 links. When I add the new node on the diagram it is very slow for me so I was doing the profiling of that execution and the output from the profiler I send as an attachment. It shows that 80% of the time is spent in the ArrangeOverride method where 74% is spent in the IsLicensed getter. Do you have an idea how to resolve this? Best regards, Milos |
Title: Re: Diagram.IsLicensed takes a long time to execute Post by Slavcho on Jul 5th, 2018 at 6:10pm
This build caches some results and should avoid the attribute calls shown in the chart -
https://mindfusion.eu/_temp/wpfdiag_attr.zip Regards, Slavcho Mindfusion |
Title: Re: Diagram.IsLicensed takes a long time to execute Post by milosa on Jul 6th, 2018 at 1:50pm
Hello Slavcho,
This actually seem to bring a drastic improvement for the performance in the big diagrams. When can we get the proper release (with a nuget package) including the fix? Best regards, Milos |
Title: Re: Diagram.IsLicensed takes a long time to execute Post by Slavcho on Jul 9th, 2018 at 11:51am
We won't be releasing soon but will try to publish this build as a nuget update. Regards, Slavcho |
Title: Re: Diagram.IsLicensed takes a long time to execute Post by milosa on Jul 11th, 2018 at 6:25am
So if you can write here when the new nuget package is available it would be great.
Thanks! |
Title: Re: Diagram.IsLicensed takes a long time to execute Post by Slavcho on Jul 13th, 2018 at 8:22am |
