MindFusion.UI controls >> WPF >> Force DrawBackground on range selector for WPF
https://mindfusion.eu/Forum/YaBB.pl?num=1540389610 Message started by notsureusa on Oct 24th, 2018 at 2:00pm |
Title: Force DrawBackground on range selector for WPF Post by notsureusa on Oct 24th, 2018 at 2:00pm
The range selector DrawBackground event only gets called on resizing of parent container. How would one force this event to be triggered without a resize event?
Title: Re: Force DrawBackground on range selector for WPF Post by Lyubo on Oct 25th, 2018 at 8:57am
The event is triggered when the background is required to render (in a Control.OnRender override). To manually force it to repaint, find the element in the range selector's template and call it's InvalidateVisual method: [code]var bckgr = range.Template.FindName("PART_Background", range) as Control; if (bckgr != null) { bckgr.InvalidateVisual(); }[/code] You can also try replacing the background control in the template with your own, and include your customization there. Regards, Lyubo |
Title: Re: Force DrawBackground on range selector for WPF Post by notsureusa on Oct 25th, 2018 at 12:33pm
Works great. Thanks!
The MindFusion Forums » Powered by YaBB 2.6.11! YaBB Forum Software © 2000-2025. All Rights Reserved. |
