Normal Topic Viewing attributes in the tree (Read 6327 times)
Matt Ashoff
Guest
Sep 8th, 2005 at 10:19am
I have a very large XML document that needs to be edited occasionally by a novice user. What I am looking for is a tree view similar to the one in XML Viewer that displays the attributes of the XML document in the tree view for easy navigation.
It could either:
1) Show all attributes (or)
2) All the used which attributes to show
This functionality is available in Oxygen XML. However, Oxygen is not only not free, but also overkill for what I need.
Other than that, thanks for putting out a great product! Smiley
Re: Viewing attributes in the tree
Reply #1 - Sep 8th, 2005 at 2:54pm
I am the guy that develops the XMLViewer , I am really glad you like it Cheesy
The viewer already shows the attributes of any selected node in the grid on the right. Doesn't that work for you ? If you need them displayed in the tree as child items of the nodes, I guess I can add an option to enable that in next release, shouldn't be much work to implement it.
Reply #2 - Sep 13th, 2005 at 12:53pm
Ok, the node attributes are now shown in the document tree:
https://www.mindfusion.org/XMLViewer.zip
You can choose to hide the attributes, to show only their values or to show both their names and values.
Matt Ashoff
Guest
Reply #3 - Feb 20th, 2006 at 12:04pm
Sorry, I lost this forum and so never thanked you for this update. It helps tremendously. Now I can basically use it as an all-purpose editor Smiley
Thanks again!
