Normal Topic MouseWheel Doesn't work?? (Read 2638 times)
Erison Liang
Guest
Dec 8th, 2005 at 12:01pm
How can I enable it that using mouse wheel to scroll large flowchart diagram?
- Erison
Re: MouseWheel Doesn't work??
Reply #1 - Dec 8th, 2005 at 12:25pm
You can use the mouse wheel by handling the MouseWheel event and changing ScrollX/Y from there. This event is inherited from the Control class, but some reason it doesn't appear in the VS event list; you must add a handler for it manually.
private void Form1_Load(object sender, System.EventArgs e)
  fc.MouseWheel += new
    MouseEventHandler(fc_MouseWheel);
void fc_MouseWheel(object sender, MouseEventArgs args)
  FlowChart fcSender = sender as FlowChart;
  float newScrollY = fcSender.ScrollY - args.Delta / 50;
  if (newScrollY > fcSender.DocExtents.Top)
    fcSender.ScrollY = newScrollY;
Erison Liang
Guest
Reply #2 - Dec 9th, 2005 at 1:11am
It works! Thanks to you.
- Erison
