Normal Topic OVERVIEW (Read 2706 times)
ARTURO PEŅA
Guest
OVERVIEW
Dec 21st, 2005 at 7:06pm
I want to know how to load the overview control.
I tried "customize toolbox"  the I browse
for
C:\Archivos de programa\MindFusion Limited\FlowChart.NET Demo\Assemblies for .NET 2.0\Overview.dll
but i got a message that the assemblie is not correct or an invalid COM Object.
I tried to add it as a reference, but I was unsuccesfull again.
Re: OVERVIEW
Reply #1 - Dec 22nd, 2005 at 10:10am
Hi ,
What version of Visual Studio do you use ? If it's a 2005 beta version it might refuse to load dlls built for the final .NET 2 version.
Arturo Peņa
Guest
Re: OVERVIEW
Reply #2 - Dec 22nd, 2005 at 12:29pm
I'm using visual studio 2002,  framework 2
I tried another PC having visual studio 2003,
and i was unsauccesfull again.
So i could not load the dll.  Cry
Thanks.
Re: OVERVIEW
Reply #3 - Dec 22nd, 2005 at 12:58pm
I didn't know one could use .NET 2 with older versions of Visual Studio. I guess the message about 'incorrect assembly format' comes from Visual Studio if it tries to validate the .NET 2 assembly using the .NET 1 runtime.
Anyway if you have VS2003, try using the dlls for .NET 1.1, which are located in the FlowChart.NET root installation folder.
Arturo Peņa
Guest
Re: OVERVIEW
Reply #4 - Dec 22nd, 2005 at 10:37pm
correct!, i load an overview.dll in an other folder and the the control was loaded correctly-
Thanks.
