Normal Topic How to Create a Box as label attached to Arrow? (Read 1800 times)
Link
Guest
Jan 15th, 2006 at 12:00pm
and Could I specify a ControlPoint or Segmenet which is attached the label box ?
Re: How to Create a Box as label attached to Arrow
Reply #1 - Jan 16th, 2006 at 7:22am
You could use a similar function to create a label box attached to a segment:
[code]
Private Function addSegmentLabel(ByVal link As Arrow, ByVal index As Integer) As Box
  Dim pos As PointF
  If link.Style <> ArrowStyle.Bezier Then
    'a segment is defined by 2 points
    Dim pos1 As PointF = link.ControlPoints(index)
    Dim pos2 As PointF = link.ControlPoints(index + 1)
    pos = New PointF((pos1.X + pos2.X) / 2, (pos1.Y + pos2.Y) / 2)
  Else
    'a segment is defined by 4 points
    Dim pos1 As PointF = link.ControlPoints(index * 3 + 1)
    Dim pos2 As PointF = link.ControlPoints(index * 3 + 2)
  End If
  Dim label As Box = flcMain.CreateBox(pos.X - 15, pos.Y - 5, 30, 10)
  label.AttachTo(link, AttachToArrow.Segment, index)
  label.IgnoreLayout = True
  Return label
End Function
[/code]
Optionally set
label.Locked = true
to prevent users from moving the label around and
label.Transparent = true
to specify that only the box text should be visible.
I hope that helps
