Normal Topic BoxCreated/BoxCreating (Read 2118 times)
Andy Sarosy
Guest
Jan 16th, 2006 at 3:37pm
I've just downloaded the demo and am looking at the FlowCharter sample (nice job on the samples btw).   Niether the BoxCreated or BoxCreating events seem to be firing.
Sample Code in the MainForm.VB:
Private Sub _flowChart_BoxCreating(ByVal sender As Object, ByVal e As MindFusion.FlowChartX.BoxConfirmArgs) Handles _flowChart.BoxCreating
       MsgBox("Creating")
End Sub
Version from FCDemo.Net.EXE is 1.0.2195.20319
Re: BoxCreated/BoxCreating
Reply #1 - Jan 16th, 2006 at 4:27pm
BoxCreated and BoxCreating are raised only when a user draws a box, but not when a box is created programmatically. The Flowcharter uses the CreateBox method to create boxes in response to drag-and-drop events, so there isn't a BoxCreated event raised.
If you need the same code to execute both when users create items and when the application creates them, you would have to add a call to the event handler method after each CreateBox.
