Here is what's new in FlowChartX 4.0.1:
*** Table enhancements ***
Rows can be assigned to distinct sections of a table. Sections can be collapsed or expanded to hide or show all rows in the section except the header one. To define a section, enable the HeaderRow property for a row. A section consists of all rows after a header row and spans to the next header. Each header row displays a +/- button that allows expanding or collapsing the section interactively. Clicking that button raises the TableSectionCollapsed and TableSectionExpanded events. Sections can be collapsed or expanded programmatically by setting the RowExpanded property for their header rows.
*** Miscellaneous ***
- SelectionOnTop specifies whether selected items are drawn on top of non-selected ones when modifying the selection.
- GetArrowAt method added to let you determine which arrow lies at a specified location in the diagram.
- Memory usage decreased with about 50 bytes per diagram item.
- Now modification cursors are displayed while item’s modification is being carried out. In previous versions the cursor was reset to the default pointer icon once modification starts.
- The SvgExporter component does not export invisible items anymore.
*** Fixed bugs ***
SaveToMetaFile did not position the background image correctly.
Evaluation copies can be downloaded here:
https://mindfusion.eu/FCXdemo.ziphttps://mindfusion.eu/FCXdemoPro.zip
