Hot Topic (More than 10 Replies) Export flowchart to visio (Read 6016 times)
Rahmy Mahmoud
Guest
Mar 6th, 2006 at 5:23am
Hi everyone
Im using the trial version of Flowchart.net, im trying to export my chart to visio file (*.vdx) using the visioExporter assembly as fllowes.
FlowChart fc = (FlowChart)Session["fcx"];
VisioExporter ve = new VisioExporter();
ve.CreateVisioGroups = true;
ve.Export(fc,"chart.vdx");
But it doesn work and doesn return any exception.
Any help is appreciated.
Bye
Re: Export flowchart to visio
Reply #1 - Mar 6th, 2006 at 7:25am
Do you use the WebChart library ? At this time the import/export components work only with the Windows Forms control.
Reply #2 - Mar 27th, 2006 at 9:06am
... or if you use the FlowChart.NET control there, make sure the VisioExport.vxt file is in the same folder where the assemblies are.
Evan Barrett
Guest
Reply #3 - Apr 1st, 2006 at 12:26am
I am also testing the Visio Exporter as well.  My application is web based, but I have finished converting all the objects from WebChart to FlowChartX.  The diagram prints nicely on the web page.  I have added an Export button to create the Visio diagram.  Here is the code that I have in the function for the button:
Private Sub btnVisio_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnVisio.Click
       fc = CType(Me.Session.Item("fcx"), MindFusion.FlowChartX.FlowChart)
       Dim VisioFile As New MindFusion.Diagramming.Export.VisioExporter
       VisioFile.ExportTablesAsGroups = True
       VisioFile.CreateVisioGroups = True
       VisioFile.Export(fc, "c:\export\test.vdx")
End Sub
I don't get any errors when I click the button, but it seems that it never creates the file.  I have put the VisioExport.vxt in the web page's bin folder (where the FlowChart.Net.dll file resides) as well as the c:\export folder.  I have also tried just using "c:\export" instead of "c:\export\test.vdx" for the vdxPathName parameter for the export function. Is there anything else that I am missing?
Reply #4 - Apr 3rd, 2006 at 6:02am
Does the ASP.NET process have write access to that folder ?
itsky
Reply #5 - Apr 3rd, 2006 at 1:16pm
I did change the permissions on the c:\export folder to allow ASPNET write permissions.  Still would not work.  I then added "everyone" write permissions in the folder.  I can successfully create .svg files, but still no luck with the Visio Exporter.
Does the VisioExporter log any kind of error message at all?
Reply #6 - Apr 3rd, 2006 at 1:23pm
Could you also take a look at the VisioExport.vxt properties - does the aspnetwp process have read access to that file ?
itsky
Reply #7 - Apr 3rd, 2006 at 1:32pm
The VisioExport.vxt file has the <local>\ASPNET account with Change permissions in both c:\export and the \bin folder for the web application.
Reply #8 - Apr 3rd, 2006 at 2:03pm
Ok, our developer traced through the Export method code and found there is some problem loading the template file while running in IIS. He will fix that in awhile.
Reply #9 - Apr 3rd, 2006 at 2:38pm
ASP.NET seems to copy the Web application assemblies to a temporary path and runs it from there, at least in debug mode, so the VisioExporter cannot find the VisioExport.vxt file. We have added a TemplatePath property which you must set to the full path of the .vxt file, and the exporter works fine when the path is set explicitly. If you need to have the fix now, let me know for which version of the .NET runtime you need the flowchart assemblies.
itsky
Reply #10 - Apr 3rd, 2006 at 2:55pm
If I could get the fix now, I'd appreciate it.  I'm running the 1.1 framework currently.
Reply #11 - Apr 3rd, 2006 at 3:23pm
I see you are our registered customer, I will email you the full version of the control in a few minutes.
itsky
Reply #12 - Apr 3rd, 2006 at 3:27pm
Thank you.
