Normal Topic Recurrence Exceptions (Read 3193 times)
rfeuer
Apr 5th, 2006 at 11:12pm
I am storing all of my appointment recurrence and exception data into a sql server database. Is there a way I can manually create exceptions for my recurrences?
Rick
Re: Recurrence Exceptions
Reply #1 - Apr 6th, 2006 at 6:14am
Exceptions can be created from code using the Recurrence.MarkException(Item, bool) method. You must provide a reference to the item occurrence, which will be marked as an exception. In order to obtain a single instance of a recurring item, call Recurrence.GenerateItems method. Currently there is no method that lets you obtain the occurrence of an item given an OccurrenceIndex.
