Normal Topic Full content viewing using text wrapping (Read 4392 times)
Danny Meirte
Guest
Apr 28th, 2006 at 9:04am
XML viewer v.3.0 is quite a help! Thanks!
The problem: viewing the full content of a value is not easy (even in a full screen width xml source window or edit window).
My suggestion:
using multilines to show larger text with text wrapping at least to show its full content when highlighting it (at mouse hoovering) and of course in the XML source window.
Maybe this text wrapping can be made available in the viewer page.
If the wrapping could be made window size sensitive this would be splendid.
But wrapping at a fixed position is probably easier to program...
Wrapping is a feature that is always needed in highlighting (=hoovering) but it should be toggled on/off by the user [under the View > options Menu] in the view window and the xml source window, and (best independently) in the edit window.
Re: Full content viewing using text wrapping
Reply #1 - Apr 28th, 2006 at 10:52am
Your suggestions are reasonable. Problem is, XML Viewer uses standard Windows tree control to render documents' contents, and this control supports neither multiline item texts, nor variable item height. We are likely to replace the tree control in the future and implement the requested features. I am not quite certain when the next version would be released though since our resources are currently dedicated to the control development department.
Thank you for your feedback,
