Normal Topic (De)SerializeTag (Read 2144 times)
ooswald
(De)SerializeTag
Jun 19th, 2006 at 10:43am
[b]could you please provide a complete example for SerializeTag and DeserializeTag?[/b]
I have objects attached to the Tag property of Boxes and AnchorPoints and am able to serialize them into an XML file:
[code]
<Box ...>
  <Tag>
    <Filter Type="-some-string-here-" />
  </Tag>
</Box>
[/code]
using the following event handler:
[code]
void Writer_SerializeTag(object sender, SerializeTagArgs e) {
    if (e.Object is ChartObject) {
       ChartObject Node = (ChartObject)e.Object;
       if (Node.Tag is IFilter) {
           // Filter element
           e.XmlWriter.WriteStartElement("Filter");
           // Type attribute
           e.XmlWriter.WriteStartAttribute("Type");
           e.XmlWriter.WriteValue(Node.Tag.GetType().FullName);
           e.XmlWriter.WriteEndAttribute();
           e.XmlWriter.WriteEndElement();
[/code]
when calling the Read() method of the XML reader, DeserializeTag gets called as expected:
[code]
void Reader_DeserializeTag(object sender, SerializeTagArgs e) {
       if (e.XmlReader.IsStartElement("Filter")) {
           Box Node = (Box)e.Object;
           string strTypeName = e.XmlReader.GetAttribute("Type");
           Node.Tag = (Activator.CreateInstance( Type.GetType(strTypeName) ) as IFilter);
[/code]
the object gets instanciated properly, however, a moment later Read() throws the following exception:
[code]
MindFusion.FlowChartX.Xml.InvalidFormatException: ControlHosts element missing or invalid
   at MindFusion.FlowChartX.Xml.XmlReader.x4cee5b00d96d6dfb(...)
[/code]
am i doing something wrong or is there a bug in FlowCharter.FX (latest build from website)?
Re: (De)SerializeTag
Reply #1 - Jun 19th, 2006 at 12:35pm
Set the Options.CustomTagSerialization property of the XmlWriter and the XmlReader to true when you use the XML reader and writer objects provided by the tag serialization events. Otherwise the control expects that you will use only the Representation property of the event arguments to save or load the tag as a simple string.
Reply #2 - Jun 19th, 2006 at 12:59pm
If you have already set these properties, make sure the reader reads as many XML elements as the writer writes, or else the control would continue reading from a wrong position in the XmlReader stream.
ooswald
Reply #3 - Jun 20th, 2006 at 5:57am
Thanks for the hint, I managed to fix the problem.
Instead of [b]IsStartElement()[/b] I'm now checking the [b]Name[/b] property (when calling DeserializeTag, the FlowChart reader has already advanced to my element).
Additionally, I added a [b]Skip()[/b] statement in order to advance to a position in the stream which is suitable for FlowChart's Read() method.
[code]void Reader_DeserializeTag(object sender, SerializeTagArgs e) {
       if ( e.XmlReader.Name == "Filter" ) {
           e.XmlReader.Skip();
}[/code]
