Hot Topic (More than 10 Replies) Change the main backcolor of an appointment (Read 19888 times)
Re: Change the main backcolor of an appointment
Reply #15 - May 10th, 2009 at 1:31pm
Have you tried using the HeaderFont instead?
andersco
Reply #16 - May 12th, 2009 at 5:50pm
Thanks that works, although when I try something like this:
style.Style.HeaderFont = new Font(calendarMindFusion.Font.Name, calendarMindFusion.Font.Size, FontStyle.Bold);
and then:
style.Style.HeaderFont = new Font(calendarMindFusion.Font.Name, calendarMindFusion.Font.Size, FontStyle.Regular);
The font doesn't seem to go back to the original font.  It is unbolded, but the size is larger and it is off-center.  Is there another property I should use other than calendar.Font in order to get the font of the days?  I am using the "SingleMonth" view.
Thanks.
Reply #17 - May 13th, 2009 at 6:03am
Try assigning null to the HeaderFont property in order to use its original value or completely remove the DateStyle from the calendar if it is not going to be used at all. Although the code you are using seems appropriate as well.
andersco
Reply #18 - May 14th, 2009 at 5:38am
Okay assigning the HeaderFont property to null works.
Thanks.
