Normal Topic Creating a Line instead of using a arrow (Read 3735 times)
James
Guest
Jul 5th, 2006 at 9:37am
Hi ,
Is there a way to draw a line instead of using the arrow option.
This option is needed to draw a plain line between 2 points.
James
Re: Creating a Line instead of using a arrow
Reply #1 - Jul 5th, 2006 at 10:01am
Do you need to draw a free-form shape, e.g. as in MSPaint ? Or you just need a straight line segment that does not connect any nodes ?
You could do the former by handling the ArrowCreating and ArrowCreated events and adding a new point to an Arrow object for each mouse movement. You can do the latter by setting AllowUnconnectedArrows = true and hiding the ArrowHead in the InitializeArrow event.
Let me know if you need sample code for that.
James
Guest
Reply #2 - Jul 8th, 2006 at 4:26am
Hi Stoyan,
Kind of you to provide sample code, will be grateful to yoo to have a look on to the same for mouse events.
James
Reply #3 - Jul 10th, 2006 at 6:05am
Hi James,
This code will draw a free-form shape when the boolean flag is set to true.
bool drawLineMode;
Arrow line;
private void fc_MouseDown(object sender, System.Windows.Forms.MouseEventArgs e)
  if (drawLineMode)
    // disable the standard FlowChart.NET mouse handling
    fc.Behavior = BehaviorType.DoNothing;
    // start drawing the line
    PointF point = fc.ClientToDoc(new Point(e.X, e.Y));
    line = fc.CreateArrow(point, point);
    line.Style = ArrowStyle.Polyline;
    line.ArrowHead = ArrowHead.None;
    line.Selected = false;
    fc.Capture = true;
private void fc_MouseMove(object sender, System.Windows.Forms.MouseEventArgs e)
  if (line != null)
    // setting the number of segments will put all points on a straight line
    // so we remember their old positions
    PointCollection points = line.ControlPoints.Clone();
    // add the new point
    points.Add(point);
    line.SegmentCount = (short)(points.Count - 1);
    line.ControlPoints.Clear();
    line.ControlPoints.AddRange(points);
private void fc_MouseUp(object sender, System.Windows.Forms.MouseEventArgs e)
  if (line != null)
    // stop drawing the line
    line = null;
    fc.Capture = false;
    fc.Behavior = BehaviorType.Modify;
James
Guest
Reply #4 - Jul 11th, 2006 at 7:32am
Dear Stoyo,
Instead of selecting and moving the object at center, I want to move the object by selecting at any point in the object.
Is there any way?
Thanks in advance.
Reply #5 - Jul 11th, 2006 at 7:35am
Dear James,
Set the box HandlesStyle to EasyMove or MoveOnly.
