glavcho :
1- Yes I can derive and extend the Frame, but of course not the Flowchart class embeded in it.
So it means that my object is now a Frame+FlowChart combo : I guess I can go on with that.
2- When I said the class I wrote is not a component, I mean it can not be used directly within the Delphi IDE in design mode to draw forms (it must be a bit extended to be registered in the IDE).
I do not say that your solution doesn't work, but that I feel it is just a work around;
I thought it would be possible to simply create the licensed component itself!
but it's ok if there is no other way.
Just for info, about the TLB file you mentionned earlier : it also contains the TFlowChart class and the connection with the ActiveX interfaces, but there is no CreateInstance in it (and no TFlowChart.Create method literally).
It's because it derives from a TOleControl Delphi Class; and I don't known now what I must/can add to the final class to create licensed component. But maybe it is here that we must dig...
thank you.
