Normal Topic AttachToNode (Read 2040 times)
Joshua
Guest
AttachToNode
Aug 3rd, 2006 at 3:00am
NodeX.AttachTo(this, AttachToNode.TopRight | AttachToNode.TopLeft);
The above compiles but fails to attach NodeX to the left and right side of "this".  Is there away to attach both the left and right sides of a node without using the percentage option or handling the resize in the box modifying event??? I basically want NodeX to stretch horizontally not vertically.
Cheers.
Re: AttachToNode
Reply #1 - Aug 3rd, 2006 at 7:03am
so you need something like the .NET controls' Anchor property? We can add this to the next release.
Joshua
Guest
Re: AttachToNode
Reply #2 - Aug 3rd, 2006 at 8:57pm
That would be perfect  Grin
Re: AttachToNode
Reply #3 - Aug 8th, 2006 at 10:55am
Hello there,
Our developers have created an initial implementation of that feature. If you wish to try it out, you can download the daily builds of the Flowchart.NET dlls here:
https://mindfusion.org/_temp/fcnetanchor.zip
The new AttachTo overloaded method can be used like this:
[code]
private void Form1_Load(object sender, System.EventArgs e)
Box box1 = fc.CreateBox(10, 10, 80, 80);
Box box2 = fc.CreateBox(20, 20, 60, 30);
box2.AttachTo(box1, GroupAnchorStyles.Left | GroupAnchorStyles.Right | GroupAnchorStyles.Top);
[/code]
