Normal Topic how refer to table location in DB design sample (Read 1411 times)
gokul Bankar
Guest
Sep 16th, 2006 at 11:34am
I am using flowchart.Net sample DBdesing and using Assemblies for .NET 2.0.
in this sample there is inbuild function Arrange
ex. tl.Arrange(fc) and u have used it in DBdesign for arranging tables.
insted of arranging tables in one line i want to arrange tables in my own manner. so i made follwing changes but its not working.i m sending my source code.second thing i have removed tl.arrange(fc) and made follwing changes in DBdesing
'Plese note some line have commented in sample code.code has been developed in .net 2005
Dim cf As ConnectionForm = New ConnectionForm()
       Dim x, y, tblcount, wdth, hgt As Integer
       Dim tbl As Table
       x = 250
       y = 150
       wdth = 100
       hgt = 120
       tblcount = 1
       cf.tbConnect.Text = _
        "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=D:\db\swadesh.mdb;Persist Security Info=False;"
       If cf.ShowDialog() <> System.Windows.Forms.DialogResult.OK Then Return
       Try
           Dim cn As OleDbConnection = New OleDbConnection
           Dim schemaTable As DataTable
           ' connect using specified connection string
           cn.ConnectionString = cf.tbConnect.Text
           cn.Open()
           ' retrieve schema information about tables.
           ' because tables include tables, views, and other objects,
           ' restrict to just TABLE in the Object array of restrictions.
           schemaTable = cn.GetOleDbSchemaTable(OleDbSchemaGuid.Tables, _
               New Object() {Nothing, Nothing, Nothing, "TABLE"})
           'iterate tables
           Dim i As Integer
           For i = 0 To schemaTable.Rows.Count - 1
               If tblcount = 1 Then ' parent table
                   tbl = New Table(fc.CreateTable(x, y, wdth, hgt))
                   x = x + 150
               ElseIf tblcount Mod 2 = 0 Then 'right side tables
                   tbl = fc.CreateTable(x, y, Width, Height)
                   'tbl.FitSizeToImage()
                   x = x - 300
               ElseIf tblcount Mod 2 <> 0 Then 'left side table
                   tbl = fc.CreateTable(x, y, 100, 120)
                   y = y - 125
               End If
               fc.Add(tbl)
               'tbl.
               tbl.Caption = schemaTable.Rows(i).ItemArray(2).ToString()
               tbl.BoundingRect = New RectangleF(0, 0, 35, 50)
               ' get columns
               Dim cmd As OleDbCommand = New OleDbCommand
               Dim tblInfo As DataTable
               Dim reader As OleDbDataReader
               ' retrieve schema from the table into a DataReader
               cmd.Connection = cn
               cmd.CommandText = "SELECT * FROM " + tbl.Caption
               reader = cmd.ExecuteReader(CommandBehavior.KeyInfo)
               ' Retrieve column schema into a DataTable.
               tblInfo = reader.GetSchemaTable()
               tbl.RedimTable(2, 0)
               ' for each field in the table...
               Dim r As Integer = 0
               Dim field As DataRow
               For Each field In tblInfo.Rows
                    tbl.AddRow()
                   ' that's the name of the columns
                   tbl(0, r).Text = field(0).ToString()
                   ' that's a .NET type, not DB one; skip 'System.'
                   Dim dotnetType As String = field(5).ToString()
                   tbl(1, r).Text = dotnetType.Substring(7)
                   r += 1
               Next field
               ' Always close the DataReader and connection.
               reader.Close()
               tblcount = tblcount + 1
           Next i
           ' explicitly close - don't wait on garbage collection.
           cn.Close()
           ' TODO: read relations
           'Dim tl As MindFusion.FlowChartX.LayoutSystem.TreeLayout = _
           'New MindFusion.FlowChartX.LayoutSystem.TreeLayout
           'tl.NodeDistance = 80
           'tl.Arrange(fc)
       Catch ex As Exception
           MessageBox.Show(ex.Message)
       End Try
    End Sub
