Hot Topic (More than 10 Replies) XML issues (Read 7474 times)
Re: XML issues
Reply #15 - Nov 8th, 2006 at 1:12pm
Ok, then saving XML through a GZipStream is the best solution for storing the diagram in a database  Wink
Phil Jacques
.NET 2.0 Rocks!!!
Re: XML issues
Reply #16 - Nov 8th, 2006 at 1:17pm
Oh geeeeze ... Wink
I didnt know that .... thanks a lot!! Cheesy Grin
But seriously, i would not like to bring in compression for my own reasons, is there a way to get a smaller size including the object??
Cheers
Phil
Re: XML issues
Reply #17 - Nov 8th, 2006 at 1:41pm
How about binary serialization to a BLOB field using the SaveToStream method?
You might need to implement ISerializable to decrease the size of the tag objects representation. Replacing the Tag objects with strings reduced the 50x70 diagram from 277K to 82K, so you will be able to implement better serialization than the one provided by the [Serializable] attribute.
