Normal Topic Flowchart cut in Overview (Read 2533 times)
Nov 8th, 2006 at 12:32pm
Try placing the Overview on the top of the form's Z order. Some other control might be hiding its last few pixels at the bottom?
Quote:
Posted by: clamPosted on: Today at 7:27am
I tried that. And I tried switching fitall off and on again. No effect
Posted by: StoyoPosted on: Today at 7:17am
Maybe it was raised before applying the Dock style, while setting the initial size. What happens if you run that code from a button click handler?
Posted by: clamPosted on: Today at 7:10am
yes
Posted by: StoyoPosted on: Today at 7:10am
Is that the overview's OnResize?
Posted by: clamPosted on: Today at 7:06am
The OnResize event gets thrown (I added an event handler). Is there something I can do inside that event handler?
Posted by: StoyoPosted on: Today at 6:50am
Well, we can't do anything if the control doesn't get the OnResize event. What exactly is the tablechartlayout you mention in the other post? If it raises any event upon layout, try running that code from the layout's event handler.
Posted by: clamPosted on: Today at 6:42am
Didn't help.
Posted by: StoyoPosted on: Today at 6:13am
For some reason the Overview control does not get the OnResize event when the Dock is applied the first time, so it does not refresh properly the tracking rectangle size. We have managed to work around this by explicitly setting the overview's Bounds in the form_Load handler:
Rectangle r = ovw.Bounds;
ovw.Bounds = new Rectangle(0, 0, 10, 10);
ovw.Bounds = r;
Posted by: Forum AdminPosted on: Today at 4:17am
*** moved from \FlowChartX\Discussion ***
Posted by: clamPosted on: Today at 12:52am
Both flowchart and overview controls are inside a tablechartlayout with dock=fill, so their size is not fix. I've send you the properties of both controls via email.
clam
Re: Flowchart cut in Overview
Reply #1 - Nov 9th, 2006 at 7:31am
I found the problem. I implemented the fitall-mechanism in my own function. The scalefactor of the overview control can't get smaller than 10. If I manually set it to 6, I'ts automatically set to 10. That's why the fitall-mode does not work. In my form, the scalefactor has to be less than 10.
Unfortunately this is not described in the documentation. I've spend a lot of time (and money) on this.
But thanks for the help.
Reply #2 - Nov 9th, 2006 at 7:45am
Unfortunately GDI+ crashes a lot when the scale is very small, so we've put 10 as a bit arbitrary guard value. I guess we can remove that limitation, but then you will have to be careful about the combined value of FlowChart.ZoomFactor and Overview.ScaleFactor - it shouldn't get less than 1% zoom.
clam
Reply #3 - Nov 9th, 2006 at 8:03am
How can I remove the limitation?
Reply #4 - Nov 9th, 2006 at 9:03am
You can't, that's hard-coded. We will remove it in the next release.
