Normal Topic How can i select arrow when it is in a bxo (Read 2265 times)
grayhound
Nov 8th, 2006 at 11:32pm
there is a group include 3 boxs, the masterObject is boxA. BoxB and BoxC are  inside boxA. there is a arrow between BoxB and BoxC.
The program is when i want to select the arrow, but the BoxA is selected.
I use the version of flowchart.net is  4.2.1  demo.
then i move boxA, but the arrow is not move
Re: How can i select arrow when it is in a bxo
Reply #1 - Nov 9th, 2006 at 6:13am
Setting the arrow's RetainForm property = true should fix that.
Reply #2 - Nov 9th, 2006 at 6:35am
... and if what you need is to be able to select the arrow with the mouse, set HitTestPriority = ZOrder.
grayhound
Reply #3 - Nov 9th, 2006 at 7:09am
Thanks very much!
I have fix the programs.
