Normal Topic Icon transparency (Read 5075 times)
gerardo
Icon transparency
Jan 30th, 2007 at 2:09pm
I have problems to displaying icons on appointments. Basically the transparency is not working. I saw the previous post:
http://mindfusion.org/cgi/Forum/YaBB.pl?board=pplanner_disc;action=display;num=1...
and I'm wondering if in the version 4.1 is there a fix or work around for this issue?
Re: Icon transparency
Reply #1 - Jan 30th, 2007 at 2:48pm
Unfortunately, we have forgotten to include a fix for this problem in version 4.1. However, I will investigate this issue tomorrow and send you a version containing a work-around for this .NET Compact Framework limitation as soon as possible.
Reply #2 - Jan 31st, 2007 at 8:40am
You can download a new version of PocketPlanner from here:
https://mindfusion.org/_planner/_PocketPlanner_41_trial.zip
The new property Calendar.ColorKey lets you specify a transparent color for all images drawn in the Calendar. You can also turn off default item rendering by settings the new property ItemSettings.EnableDefaultRendering to State.Disabled.
gerardo
Reply #3 - Jan 31st, 2007 at 1:31pm
The new property Calendar.ColorKey is working fine Cheesy and the icons are displayed perfectly.
The other property: ItemSettings.EnableDefaultRendering is not working properly. I used
HHCcalendar.ItemSettings.EnableDefaultRendering = State.Disabled
and now in DayRange View the appointments are not rendered. If I change the property value to enabled, the appointments then will be rendered twice when they are selected (I'm using custom drawing)... Undecided
Reply #4 - Feb 1st, 2007 at 5:41am
