Normal Topic SegmentCount (Read 2833 times)
Jens Evers
SegmentCount
Feb 5th, 2007 at 11:09am
I'm not able to increase the number of segments of an existing arrow.
[code]
MindFusion.FlowChartX.Arrow arrow;
// node1 and node2 both exists
arrow = FlowChart.CreateArrow(node1, node2);
// Style is Cascading
// SegmentCount is now 2
arrow.SegmentCount = 5;
// SegmentCount is unchanged and still 2
[/code]
The created arrow is drawed correctly, but i cannot increase the number of segments. I want to add some control points. After calling [i]UpdateFromPoints()[/i], all control points are correct and visible! But only the first segments of the arrow are drawed, because the number of segments is unchanged! And i cannot change the number of segment manually (see example)! Only if i move the origin or destination node/box, all segments of the arrow are drawed completely.
Best regards,
Jens Evers
Re: SegmentCount
Reply #1 - Feb 5th, 2007 at 11:26am
You cannot change the number of segments if Arrow.AutoRoute is enabled. Could you check what's the AutoRoute value for your arrow?
Best regards,
Jens Evers
Re: SegmentCount
Reply #2 - Feb 5th, 2007 at 12:24pm
Okay! AutoRoute was enabled during setting SegmentCount! With the following code, it works fine!
[code]
// SegmentCount is now 2 (for example)
arrow.AutoRoute = false;
arrow.AutoRoute = true;
// SegmentCount is now 5
arrow.ControlPoints.Clear();
// p1 ... p6 are given control points for the 5 segments!
arrow.ControlPoints.Add(p1);
arrow.ControlPoints.Add(p2);
arrow.ControlPoints.Add(p3);
arrow.ControlPoints.Add(p4);
arrow.ControlPoints.Add(p5);
arrow.ControlPoints.Add(p6);
arrow.UpdateFromPoints();
[/code]
Thanks for your prompt reply!
Jens Evers
