Normal Topic TimeTable view (Read 3314 times)
Jeffry
TimeTable view
Feb 13th, 2007 at 12:27pm
In the TimeTable view you can scroll from the StartTime to the EndTime. However, I want the initial display to have the start of the working day visible. So starttime is 00:00 and start working day is 08:00. Can I automatically scroll to 08:00? Or do I need to use external navigation buttons for this (just like with the example you gave to scroll through the weekview).
Jeffry
Re: TimeTable view
Reply #1 - Feb 13th, 2007 at 12:39pm
Try settings the Calendar.ScrollPosition directly. For example, if you are using 1 hour per cell (which is the default), you have to specify 8 as the Y value of the scroll position. Similar to the following:
calendar.ScrollPosition = new Point(calendar.ScrollPosition.X, 8);
Jeffry
Re: TimeTable view
Reply #2 - Feb 13th, 2007 at 4:48pm
Excellent! I have to take a closer look at the API before I ask questions  Smiley
