Normal Topic ItemHeader in TimeTable (Read 2878 times)
Jeffry
Feb 16th, 2007 at 10:13am
Is there a way to make the item header in the timetable view as large as the whole duration of the item?
In other words, don't display the description area, but only the header. The reason, often the headertext is just too large to display in the small header area, so I would like to use the area of the descriptiontext.
Now, when I have an appointment that spans 5 cells. I have one small cell for the headertext and 4 emtpy cells.
Re: ItemHeader in TimeTable
Reply #1 - Feb 16th, 2007 at 10:35am
The height of the item header is determined by the ItemSettings.HeaderSize property. It cannot be made precisely as big as the item but you can specify a large enough number to ensure it will fit even the tallest item. For example you can set a value of 1000.
