Normal Topic ShapeTemplate and Image (Read 3282 times)
meriturva
Feb 27th, 2007 at 6:30am
I need to insert and image into a ShapeTemplate.
This is the code i wrote for a simple test:
[code]
Bitmap bitmap = new Bitmap("ResourceFiles\\SynopticsIcons\\test.png");
bitmap.SetResolution(96, 96);
ShapeTemplate st = new ShapeTemplate(new ElementTemplate[] {}, FillMode.Winding, "test");
st.Image = bitmap;
st.ImageRectangle = new RectangleF(0, 0, 100, 100);
Box box = flowChart_Synoptic.CreateBox(10, 10, bitmap.Width, bitmap.Height);
box.Shape = st;
box.Style = BoxStyle.Shape;
[/code]
I don't know why but there is no image displayed.
Where could i find a running example?
Meriturva
Re: ShapeTemplate and Image
Reply #1 - Feb 27th, 2007 at 6:39am
Perhaps it does not work because the list of outline elements is empty. Try how it will work if the outline is defined, e.g.:
     ShapeTemplate.FromId("Rectangle").Outline, FillMode.Winding, "test");
Set the Box.Transparent property if you do not want to see the box shape but only the image.
meriturva
Reply #2 - Feb 27th, 2007 at 7:10am
Perfect!
Thanks...
I have another litte question....
When i create a new Box i use:
[code]
Box box = flowChart_Synoptic.CreateBox(10, 100, bitmap.Width, bitmap.Height);
[/code]
but the size is not correct (bigger than normal)
I would like to know where is the measure unit of the width and height  in CreateBox.
In the documentation i have:
width
The width of the box to draw.
height
The height of the box to draw.
There is no indication about pixel o mm o cm?
Meriturva
Reply #3 - Feb 27th, 2007 at 7:23am
The width and height are measured in the unit specified in FlowChart.MeasureUnit. The default is mm. You might call Box.FitSizeToImage and the control will calculate the correct size for you.
meriturva
Reply #4 - Feb 27th, 2007 at 7:41am
I think that the code:
[code]
[/code]
It is the left-top pixel where to start the image (respect to the shape) and the % of the width and height  (respect to the size of the shape).
am i correct?
So the Box.FitSizeToImage doesn't work (i think it is valid only when you use box.Image and not Shape.Image and Shape.ImageRectangle)
So i prefer to rescale by my self the shape with:
[code]
Box box = flowChart_Synoptic.CreateBox(10, 100, (float)(bitmap.Width * 25.4 / bitmap.HorizontalResolution), (float)(bitmap.Height * 25.4 / bitmap.VerticalResolution));
[/code]
Thanks again for your great support.
Meriturva
Reply #5 - Feb 27th, 2007 at 7:50am
FitToImage is supposed to work with the ShapeTemplate.Image too. In that case you must call the method after Box.Style is set to BoxStyle.Shape and the Box.Shape is assigned.
meriturva
Reply #6 - Feb 27th, 2007 at 7:59am
You are right,
the FitSizeToImage call must be after the
[code]
box.Shape = st;
box.FitSizeToImage();
[/code]
Thanks.
Meriturva
