Normal Topic Single Month View - Multiple Appointments (Read 2044 times)
bpeacock
War Eagle!
Mar 8th, 2007 at 1:22pm
I am using the single month view and have mulitple appointments per day.  What do I need to set so that the appointment details can be seen while viewing the calendar?  I only see the "header Text" for appointments on a given day.
Re: Single Month View - Multiple Appointments
Reply #1 - Mar 8th, 2007 at 2:04pm
Unfortunately item description is never displayed in a SingleMonth view. You can however use custom drawing or custom item viewers in order to display the items in the way which suits you best.
bpeacock
War Eagle!
Reply #2 - Mar 8th, 2007 at 5:20pm
I set the "Subject" property = Row one text + System.Environment.NewLine + Second row text.  I adjusted the "Size" property as well.  This works for what I need.
