Normal Topic Select timerange (Read 3948 times)
Jeffry
Select timerange
Mar 20th, 2007 at 9:44am
Is it possible to select a timerange, e.g. in the TimeTable view click on 9:00 and then drag to 11:00 and select that range?
Re: Select timerange
Reply #1 - Mar 20th, 2007 at 9:47am
Simply tap and hold over 9:00, then drag the stylus down to 11:00 without releasing it.
Jeffry
Reply #2 - Mar 20th, 2007 at 9:53am
It doesn't do that, it keeps selecting the next field when dragging. Maybe it's code I have in other eventhandlers that prevent this.
Or is there some property I need to set to enable this?
Reply #3 - Mar 20th, 2007 at 10:54am
Hmm, the only thing I can think of is to set Calendar.Selection.AllowMutliple to State.Enabled. Enabled is the default value of this property but you might have changed it at some point.
If this doesn't help I will appreciate it if you can send me a sample application that reproduces this behavior.
