Normal Topic Timetable view - Hide Header? (Read 2900 times)
Anna
Mar 20th, 2007 at 10:05pm
I was wondering if it's possible to hide the header that displays the date in the Timetable view.
I still want to see the "All Day" Items but not see the date at the top. Is this possible?
I've set both the Mainheadingsize and subHeadingSIze to be 0 but it still shows..
Thanks for your help,
Anna
Re: Timetable view - Hide Header?
Reply #1 - Mar 21st, 2007 at 5:00am
Unfortunately this is not possible yet. You can however specify 1 pixel for the header height and remove the header text. Here is the code for this:
calendar1.TimetableSettings.HeaderDateFormat = "  ";
calendar1.TimetableSettings.MainHeaderSize = 1;
Note: Pay attention that the format of the header text is two spaces. It seems that DateTime.Format gives errors when trying to use only one space as a formatting string.
This way the header will look like a thin line. You can alse set the color of that line through the HeaderBrush property of the appropriate Style object. The followig code sets the color to White.
calendar1.TimetableSettings.Style.HeaderBrush =
    new MindFusion.Drawing.SolidBrush(Color.White);
