Normal Topic Appointment fill color (Read 6299 times)
bpeacock
War Eagle!
Mar 27th, 2007 at 11:26am
I am populating a calendar with appointments and need to set the fill color to specific colors based on a status.  The color with not set.   I am trying this with single month and timetable views.   The border color will set fine.  Is there a calendar level attribute that may be causing this?
Funny thing is this is working in another part of the application I am working on.  These are separate calendars.  One works and one doesn't.
Re: Appointment fill color
Reply #1 - Mar 27th, 2007 at 11:48am
Have you tried settings the Brush property of the Style object associated with the item? For example if 'item' is a variable referencing the Item whose background color you would like to change, here is a sample code that should do this:
item.Brush = MindFusion.Drawing.SolidBrush(Color.Green);
bpeacock
War Eagle!
Reply #2 - Mar 27th, 2007 at 12:43pm
I have a class that inherits the calendar and the code below is from a sub that is used when I  loop through my dates and add appointments to the calendar.  The appointments add fine but the fill color just doesn't set.  The border color will set just fine.
Appointment appt = new Appointment();
appt.Subject = "Some subject";
appt.Details = "Some details";
appt.StartTime = Some StartTime;
appt.EndTime = Some end time;
//Some logic goes here that determines a specific color to use below.
//Defaulted to red for this example
Color color = Color.Red;
//I tried this
appt.Style.Brush = new MindFusion.Drawing.SolidBrush(color);
//and tried this
appt.Style.FillColor = color;
//I am setting border colors as well and this works
//Example for just the top border
appt.Style.BorderTopColor = color;
appt.Style.BorderTopWidth = 1;
//Add the appointment to the schedule
base.Schedule.Items.Add(appt);
Reply #3 - Mar 27th, 2007 at 1:51pm
What happens if you set the Style.HeaderBrush?
bpeacock
War Eagle!
Reply #4 - Mar 27th, 2007 at 2:22pm
I tried this
appt.Style.HeaderBrush = new MindFusion.Drawing.SolidBrush(Color.Red);
Still doesn't fill the box.  Border is red and the center box is a blue color.
If you are at the calendar level, and set this
this.ItemSettings.Style.Brush = new MindFusion.Drawing.SolidBrush(Color.Red);
the box fills, but this is for all appointments.  I need to be able to color appointments with different colors based on logic.
It seems like something at the calendar level is overriding the color I set when loading appointments.
Reply #5 - Mar 27th, 2007 at 2:44pm
Are the items selected, by any chance? You would have to use the SelectedStyle.Brush to change the fill color of selected items. Could you also try to display the Style.Brush values for all items upon a button click, to check if they aren't changed at some point after you initially set them?
bpeacock
War Eagle!
Reply #6 - Mar 27th, 2007 at 4:24pm
The appointments(items) are not selected.  I can try the button click.
