Normal Topic Compile errors in tutorial (Read 6229 times)
donaldkelley
May 22nd, 2007 at 2:30pm
I have downloaded Planner.NET trial version and am working thru the tutorials as evaluation.  In tutorial 2 the following code is specified.
Recurrence rec = new Recurrence();
rec.Pattern = RecurrencePattern.Weekly;
rec.DaysOfWeek = DaysOfWeek.Monday | DaysOfWeek.Wednesday;
rec.Weeks = 2;
rec.StartDate = new DateTime(2006, 1, 10);
rec.StartHour = 14;
rec.StartMinute = 0;
rec.EndHour = 16;
rec.EndMinute = 30;
rec.RecurrenceEnd = RecurrenceEnd.Never;
The lines with rec.StartHour, rec.StartMinute, rec.EndHour, rec.EndMinute give compile errors - properties do not exist
Please help
app.Recurrence = rec;
Re: Compile errors in tutorial
Reply #1 - May 22nd, 2007 at 2:40pm
The StartHour, StartMinute, EndHour and EndMinute properties have been removed from Recurrence. Now the recurrence uses the start and end time of the associated master item instead. This was done to enable recurring items with arbitrary length and spanning more than one day.
donaldkelley
Reply #2 - May 22nd, 2007 at 4:02pm
thanks Stoyan
bytesighs
Reply #3 - Sep 22nd, 2008 at 12:25pm
ok, so how do we use the recurence, any example?
Reply #4 - Sep 22nd, 2008 at 12:59pm
Assign it to some Appointment object as shown in Tutorial 2 in the help file. This turns the appointment into a recurrent item, and when you add it to the schedule, you should see its multiple instances.
