Normal Topic Is code obfuscated? (Read 3179 times)
ymoran00
Is code obfuscated?
May 26th, 2007 at 8:07pm
I have tried to look into the JDiagram code many times to understand some flows, and found a very hard to understand code. Is it obfuscated?
If it is, if I buy the code, will I have access to the regular one?
Yoav
Re: Is code obfuscated?
Reply #1 - May 27th, 2007 at 3:59pm
Yes, the compiled code is obfuscated. You will get the full source code, as an Eclipse project, if you buy the code license.
